Please I need help to identify a 5 pin SMD Semiconductor "KV5MK"
DJKH
Dec 25, 2016
3
Hi, please help me identify an SMD semiconductor that I found burnt in a sircuit board I am trying to repair, it has 5 pins and it is labeled "KV5MK" I need some equivalent replacement SMD to replace it.
Thank you for your help.
ramussons
Jun 10, 2014
475
If you tell us what circuit board you are trying to repair, maybe a few photos of the component,...., it would help us to help you :D
DJKH
Dec 25, 2016
3
Thank you for your reply, the circuit board is for a LooL IPTV receiver, the user lost its original power adapter plug (output 5V) so he tried a different plug with output 12V that is when that component get burnt. Please check the pictures (On red is the damaged part, on green is the same component in a different spot on the board):
Thank you again for your help.
14,484
putting 12V into something that requires only 5V is a bad thing .... there is most likely more than that one
component that is damaged .... a component can be zapped without any visible external damage
seeing where they are on the board and the surrounding components, they most likely are switching regulators
I cant seem to find any references for it online
DJKH
Dec 25, 2016
3
Thanks Dave, so it is going to be hard to fix this board :( ...
