PLL Loop filter
Andrew Holme
This PLL loop filter is used with current-output charge-pumps:
GND
| .-| Z |-.
i_N | ___ | |\ |
-->----o---|___|--o--|-\ |
___ | >-o---
-->----o---|___|--o--|+/
i_P | | |/
--- | Z |
GND ===
GND
Z is an R and C in series, optionally paralleled with another C.
This circuit can be used with voltage-output phase detectors; but the
single-ended input impedances are not equal:
GND
| .-| Z |-.
___ | ___ | |\ |
VN --|___|---o---|___|--o--|-\ |
___ ___ | >-o--
VP --|___|---o---|___|--o--|+/
--- | Z |
GND ===
GND
This circuit seems to have better input balance over a wider frequency range
and is simpler:
GND
| .-| Z |-.
___ | ___ | |\ |
___ ___ | >-o--
--- === 10uF
GND GND
Is there a downside?
TIA
Andrew Holme
GND
| .-| Z |-.
i_N | ___ | |\ |
___ | >-o---
i_P | | |/
--- | Z |
GND ===
GND
GND
| .-| Z |-.
___ | ___ | |\ |
___ ___ | >-o--
--- | Z |
GND ===
GND
range and is simpler:
GND
| .-| Z |-.
___ | ___ | |\ |
___ ___ | >-o--
--- === 10uF
GND GND
TIA
A few more details for clarity: I'm using an AD9901-style PFD inside an FPGA
which feeds this circuit differentially, via LVDS out of the FPGA and is
then level shifted to CML to get the common mode voltage up enough that I
don't need a negative supply for the op-amp.
Similar threads
