Plugging cryostat designed for 50Hz into 60Hz but same voltage
Simon
Hi, Everyone!
Cryostat is device that has electronic components and compressor. I
have a cryostat that is designed for 220-230V 50Hz. If I plug it into
220-230V 60Hz, what is going to happen?
What I understand is that frequency change may cause current change
depending on change of the impendance. How is the impedance of the
compressor changed? What kind of circuit is usually in compressor? (in
terms of R, L and C).
jasen
Hi, Everyone!
might work, might fail.
it's probably an induction motor, if so 60 hz will cause it to try to go
faster, it'll use more power and get hotter, may die, may survive.
if it dies a refrigertor mechanic will be able to replace it with one
designed for 60Hz
terry
if it dies a refrigerator mechanic will be able to replace it with one
designed for 60Hz
Maybe. But operating at 60 instead of 50 means that the reactance of
the motor may be higher.
Viz: 2 x pi x (FL) most likely limiting the current slightly.
Usually little problem going from 50 to 60? But even if the motor were
to 'struggle' a little on 60 with the reduced current thus tending to
slow down, it will then draw more load current to operate the load?
However when going the other way; 60 to 50, some small and marginally
engineered units don't like it!
My 60 hertz shaver got damnably hot on 50 hertz although the voltage
was correct!
Didn't measure it but estimated that 50 cycle current, could be 60/50
= 1.2 times that at 60.
And I squared (1.2 x 1.2) = 1.44 or almost one and half times the power
dissipation?
Just a coupla of thoughts!
Simon said:
Hi, Everyone!
.. Check with the manufacturer.
2. Try it and see. Use independent temperature measuring equipment to
verify correct operation.
There will likely be a motor which powers a reciprocating compressor.
The motor may or not, depending on design, run slightly faster than
designed, by a factor of 6:5. The electronics will be supplied with low
voltage DC and will most likely be unaffected. I doubt that correct
temperature sensing will be affected. It will probably operate OK. You
are very unlikely indeed to harm the device by connecting it to a 60Hz
supply.
