Plugging cryostat designed for 50Hz into 60Hz but same voltage
Simon
Hi, Everyone!
Cryostat is device that has electronic components and compressor. I
have a cryostat that is designed for 220-230V 50Hz. If I plug it into
220-230V 60Hz, what is going to happen?
What I understand is that frequency change may cause current change
depending on change of the impendance. How is the impedance of the
compressor changed? What kind of circuit is usually in compressor? (in
terms of R, L and C).
Donald
Simon said:
Hi, Everyone!
Have you looked inside this unit ?
I would venture a guess that the electronic components run off a DC
power supply. The DC power supply may handle thet 50Hz with out any
problems.
The compressor may use a different power supply that uses the 50 Hz
input directly.
So, open it up a take a few pictures and show us all what you found.
donald
Donald
problems.
input directly.
donald
Holy Cow,
Google had over 2 million hits on cryostat.
Now that I know its an instrument name, not a manufacture name, I would
ask whom is the manufacture ??
Without more information, we (I) am only guessing.
good luck
donald
Simon said:
Hi, Everyone!
Contact the manufacturer. They wil be able to answer directly. If they
could, they would have designed a system that coud run from both 50Hz
and 60Hz mains supplies, but if the compressor motor runs directly from
mains AC you could be in trouble.
Even then swapping the compressor motor mght well be cheap and fairly
easy.
Simon said:
... cryostat that is designed for 220-230V 50Hz. If I plug it into
Well, I'd assume it will work fine. The AC motors (if any) might have
slightly reduced torque and higher speed, and any AC solenoids (for
solenoid-operated valves or relays) might get a tad warmer (and weaker
in their function), but it's unlikely anything critically depends on
the line frequency. Certainly most electronics runs from
regulated DC power, and would be unaffected.
Safest, of course, to ask the manufacturer; they might even ship you
an amended nameplate to bless the different power source.
If noise is an issue, beware! Those different motor speeds mean all
the
factory noise reduction was tuned for a different set of notes...
