PNP and NPN replacements
walid1
Jun 27, 2004
749
I an not so familiar with PNP type transistor.
when I see a PNP tran. in any circuit like one that shown below that using a PNP, I immediately think to replace - at least in mind- with NPN.
If I want to do so I must invert the power supply. is this what must to do or there are many other things?
thanks
Another question about the circuit below:
I see a hartly osc. before many times and noticed that the tank circuit conected-always- between Vcc and collector and not base and Vcc. What the difference?
thanks
prateeksikka
Jun 19, 2004
736
hi walid !
it is a golden rule in electronics that NPN and PNP transistors can be interchangably used in any electronics circuit by slight modification.
But in general we go for NPN transistors including me and u know the reason behind this is too simple-------
"Electrons have higher mobility than holes!!!"
8)
audioguru2
Apr 6, 2004
12,026
All Hartley oscillators feed the inverted signal from half the center-tapped coil to the transistor's base. This circuit has the other half of the coil as the collector's load through C3, since the RFC coil is a very high impedance (inductive reactance) at the operating frequency.
prateeksikka
Jun 19, 2004
736
hi audioguru!
i remember feeding oscillator outputs to antennas in many cases.
Are antennas inductive in nature  or capacitive generally?
i mean if i measure the impedance of an antenna what will it be?
R+jX what will be X?
thanks in advance.
audioguru2
Apr 6, 2004
12,026
The impedance of an antenna depends on its length and its percentage of the wavelength of the signal, doesn't it? I think it has a perfect resistance at a quarter and at a half of a wavelength and one is low and the other is high. In between, the impedance is capacitive or inductive.
prateeksikka
Jun 19, 2004
736
does impedance depend on the frequency of the signal by which it is fed?
audioguru2
Apr 6, 2004
12,026
The wavelength of the signal is determined by its frequency so the impedance of an antenna would also change unless you changed the length of the antenna to match.
prateeksikka
Jun 19, 2004
736
Yes and length of antenna is inversely proportional to frequency of the input signal.Right?
If i feed an antenna with very high frequency say in GHz an ntenna of few mm may be enough but if the frequency is audio say 20Hz height is in kms.
Then why dont we use the never ending upper limit of the spectrum for communication purposes?
like in GHz.i guess FM range is only a few MHz.plz reply
audioguru2
Apr 6, 2004
12,026
prateeksikka said:
length of antenna is inversely proportional to frequency of the input signal. Right?
Correct.
like in GHz.
We are using higher frequencies now. New wireless phones for homes operate at about 12.xGHz. My old one operates at 900MHz which is high enough for me.
NASA uses some extremely high frequencies.
Alun
If you're talking about RF the spectrum isn't never ending, you get to about 300GHz and the air becomes opaque to the radiation, and we get to an odd and largly unexplored regon called terahertz radiadion, it's in between far infrared and microwaves and is quite interesting.
http://en.wikipedia.org/wiki/Electromagnetic_spectrum
http://en.wikipedia.org/wiki/Terahertz_radiation
audioguru2
Apr 6, 2004
12,026
You have to be a certified plumber to work on electronics that operates that high. ;D
prateeksikka
Jun 19, 2004
736
hi audioguru hi alun!
alun just said the spectrum is not never ending.what puts a limit to this spectrum is it the more affecting of noise at such high frequencies or distortion or something else?
