This only applies to PNP / NPN Bipolar transistors. (3906 & 3904 examples)
A handy way to remember how they work is to remember what they look like inside.
a PNP is made of 3 regions, Positive, Negative and Positive again. NPN is the same but reversed.
In a diode there are only 2 regions, P and N. Electron flow is from the N to the P. (Cathode to Anode)
Basically a PNP is the same as two diodes "Pointing" at each other (Cathodes connected)
and NPN has the Anodes connected "Pointing" Away from each other.
Where the diodes meet is called the Base.
The BASE to EMITTER flow is the same as the diode that makes it up.
n-PN has the electron flow from the Emitter to the base (Base more positive than emitter)
p-NP has the electron flow from the Base to the Emitter (Emitter more positive than Base)
The current flowing between the collector and emitter, in simple DC terms, is the "Hfe" or "Beta" of the transistor times the current between the Base and Emitter.
0.01ma current at Base times a beta(Hfe) of 120 = 1.2ma current through Collector.
(Remember the current at the Emitter is the BASE current PLUS the Collector Current
in this case 1.2ma plus 0.01ma = 1.21ma)
Anyone want to know what a Q point is?
-Mike
