Jamie M
- Jan 1, 1970
- 0
I was thinking of an alternative to superconductors to transmit
electricity with low (or zero) resistance. If there is a wire used
which has a fixed resistance but is able to regenerate some of the lost
energy that is lost to resistance, then it would have an effective
resistance that is lower. I think they key is to structure the wire
so the losses happen in a way that they can be regenerated. I was
thinking maybe something like a diode could work. ie. The wire would
be a stretched diode turned sideways, so that the P and N of the
diode are at the start of the wire and also the same P and N sections
are at the end of the wire. Then if the current is sent down the
interface of the diode between the P and N on the anode side, then if
there is resistance in the "wire", it will create phonons at the diode
junction, and they can be pumped by the diode back into the wire if the
cathode of the diode is routed back to the anode at the area that the
electrical loss occurs. Would something like this work? It is similar
to a solar panel for collecting electricity, but instead of using
photons from the sun, it is using phonons from electrical resistance
losses.
cheers,
Jamie
losses.
cheers,
Jamie
