Possible damage to computer and TV after installation by Comcast Subcontractors
John Smith
Moved into a new house (3 years old) and had an appointment to get Comcast
Cable TV and High Speed Internet installed.
Comcast sent subcontractors to do the job. In the cable box OUTSIDE the
house (a green enclosure) they found that the tap that goes into my house is
broken so they put a splitter on the neighbors cable line, so both me and
the neighbor now share the cable connection.
After few hours the computer goes dead. It does not power on at all. The PC
is located upstairs and is plugged into a surge protector along with the
monitor. The monitor is working fine.
After few hours the downstairs Sony Wega goes blank and there is sound and
no picture. A red light in front of the TV is blinking which according to
the manual "TV needs service. Contact Sony service center". The TV was
plugged in to a good surge protector also.
My question is as follows: .is this a coincidence that I lose both a
computer and TV the same day cable tv installation is done... all in a
matter of few hours?
OR
Can faulty cable tv / high speed cable Internet installation cause damage to
the computer and television?
thanks,
John
Robert Morien
OR
thanks,
John
How's your neighbors tv and computer doing?
Al Bundy
OR
thanks,
John
I was starting to buy the coincidence until I read down to the TV
failing. Has anything happened to the neighbor's appliances? I would
start by getting a TV diagnosis telling them what might be related.
Leonard Caillouet
Yes, it is likely a coincidence. You might simply check to be sure that
there is no voltage on the cable relative to ground on your AC service, but
it is unlikely that what they did caused a problem. It is possible that
your neighbor could be using the cable line to distribute some DC for an amp
or sat system and does not have the proper blocking devices.
Did they connect the cable from next door to a ground block before it
entered your house? If not, it is conceivable, though not likely that there
could be a grounding issue.
Once the units are diagnosed, ask the techs what might have caused the
problem, without telling them the scenario. Likely the answer will be
random failure, or perhaps not so random typical failures in each unit.
Leonard
Jamie
Couldn't find the orginal message so i will tack this one.
i have seen that before. neighbor has a ground fault problem
between his outlet and TV/Cable box set. possibly a miss wired
outlet surging about 220v up the line at the correct moments.
cable company should not put him on a direct connection to the
neighbors line, it should have been Decoupled/isolated other than
RF.
Al Bundy
Leonard
The mean time before failure on a TV is between 15-30,000 hours and
possibly more for the PC. Even if both were very old the chance of
both going together is almost zero. The only question is whether you
can prove it and get some satisfaction.
F
fecal control unit
thanks,
John
Might want to disconnect the neighbors cable & grab a DMM to see if
there's an AC voltage{ & current?} diff between your box/neighbors
cable ( test both shield/ground & center conductor).
{I've seen 120 VAC, 120 mA between my old fridge & the kitchen sink!}
James Sweet
Yikes, sounds like you had a grounding issue in your house's wiring, that
could be a dangerous situation.
