Power backup
kenton
Apr 10, 2023
An old 800 W eliminator power pack battery is cooked.
Would like to take the inverter out and hook it to a large marine battery to use it for power outages not sure on the wiring process I do not want display radio or light just the inverter and the battery and 110 output, with an off switch.
kenton
Apr 10, 2023
Here is more pics hope they are good
kellys_eye
Jun 25, 2010
6,512
What you have seems to be a simple inverter. DC power input on the thick red (positive) and black (negative) wires. You MUST use a fuse (30A) in the red lead.
Connect to the battery and switch on. You should, if the unit is working, get AC at the sockets. Make sure you reconnect that loose yellow/green earth wire.
Most importantly of all THERE IS LETHAL VOLTAGE AT THE OUTLET SOCKETS. Proceed at your own risk.
melvinlcotto
Mar 29, 2023
3
To connect it to a large marine battery, you need to ensure voltage compatibility and use appropriate gauge cables. Connect the inverter terminal to the positive terminal of the battery and the negative terminal of the inverter to the negative terminal of the battery. Install an inline switch between the inverter and the battery to control the power flow. Remember to follow safety precautions and consult a professional if unsure about the wiring process.
