W
Watson A.Name - Watt Sun, Dark Remover
- Jan 1, 1970
- 0
I got two Power Designs PS-2005A Precision sources from two different
sellers on Ebay, and they both work, somewhat. They put out up to
20VDC at a half amp, so they can serve as a power supply. They're
real old, made back in the early '70s so they're an all discrete
design. Essentially they're a linear power supply with a reverence
(yeah right
diode in an oven. The circuit furnishes a 1 mA
precision current to a series of switched resistances from 0 to 20k,
giving 0 to 20V. I posted half of the schematic on the
alt.binaries.schematis.electronic newsgroup.
The problem seems to be the switches. There are two rotary switches,
each having dual concentric rotors. These are arranged to give 0 to
10k. There is a 10k .01% resistor with a switch shorting it, to add
to the switches to give the 10 to 20V. Another 1 ohm pot called the
vernier is in series to vary the voltage by a millivolt. I can
replace the DPDT switch across the 10k .01% resistor, if I find that
it's so intermittent that it doesn't make good contact. But the
rotary switches are a whole 'nother story. All these switches can be
bypassed by setting them to zero and putting a 0 to 20k resistance
across the terminals on the back. I could put a 20k ten turn pot
there and make it into a power supply, losing the discrete settings
the switches give. But I'd like to fix the switches if I can,
obviously.
I was thinking of giving them a bath in tuner cleaner or some kind of
cleaner to get rid of the intermittent problems. But one switch
doesn't go thru the voltage steps correctly, so I may have to find
that problem. My main question is how to get the rotary switches back
in shape and get rid of the intermittent switch problems. I ran the
switches thru the full ranges quite a number of times to get the
contacts to wipe a lot, hopefully to clean some of the tarnish off
them.
I have some tuner lube, I thought it might be good to lube the switch
contacts after I clean them. One of the units smells of smoke, so I
guess I'll have to clean it up and get rid of the dust and grime in
it. The units are built well, all aluminum with easy access to stuff.
The circuit board is just drilled and eyelets put in for the contacts.
Basically point to point wiring. I have one concern that if I mess
with any of the precision resistors, they probably can't be replaced,
or else I'd have to use lower tolerance parts. So I gotta be careful
about those. Anywqay, thanks for any ideas.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
(yeah right
obviously.
them.
