audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
Hi Guys,
Why is this simple multivibrator inverter included in the Projects Section of this high-quality site? It is here:
http://www.electronics-lab.com/projects/power/018/index.html
The author claims that it will deliver 300W as shown.
Has anyone built it? Unfortunately, it has problems:
1) If the parts values and transistor gains are identical, then when it is turned-on both transistors may conduct at the same time and latch-up. Then it will blow the....., well it doesn't have a fuse, so something will get mighty hot.
2) With only 63mA of base-drive from R3 or R4 (180 ohms), if the 2N3055 transistors have their minimum-spec'd gain, then the output would be only 39W. (I know, the capacitors boost the base current, but only for a moment).
3) The capacitors cause the reverse-bias maximum voltage rating of the base-emitter junction of the transistors to be exceeded, causing damage.
4) The capacitors are shown backwards.
No, I don't want to re-engineer it, I think that it should be removed from this site.
