I need some help building a simple circuit (logic wise it's simple, that is). I can build it with three mechanical relays, but I'd prefer to do it with solid-state components. Unfortunately my electronics knowledge doesn't extend much beyond a basic understanding of simple components.
Here what it needs to do:
I have two switches, switch 1 & switch 2, which send 12 volts to two different automotive components. The switches are "latching", not momentary. When switch 1 is turned on I want to light LED 1. When switch 2 is on, I want to light LED 2 (I know how to do that part of the system). However, when BOTH switches are on, I want to detect the "AND" condition and light a third LED 3 while shutting off LED's 1 & 2. If switch 1 or 2 is shut off, it should fall back to lighting the proper LED 1 or 2 and drop power to LED 3. I don't need any serious power through the circuit, the main switches take care of that, I just need to light the LED's.
Are there some logical components I can use to do this (and I need hand holding... my skills are more limited than you think
