Power mains question: wire gauge
Sigh. I didn't need any last week. in fact, i have more wire than I
need now, and for the rest of my life.
I did. You obviously haven't the faintest clue what you're talking
about, then.
No answer?
Yes, I lost the race to prove stupidity. I didn't even get off the
starting line. Congratulations.
You've admitted that you haven't a clue about the costs involved. You
lose.
W
WoolyBully
Not 36 gauge. 36 wires in the bundle to be pulled.
Pully Bully
DraconisExtinctor
Perhaps not, AlwaysWrong, but you supported the idea.
<more DimBulb screed snipped>
No, I did not, idiot. I was the FIRST one to suggest plastic. At NO
TIME did I suggest, or support PVC, you fucking illiterate retard.
You *certainly* did, AlwaysWrong.
Me: "The plastic (PVC) I've seen is *not* recommended for air supply."
DimBulb: "Then, water pipes must not be the solution of which I
speak."
Implying that it's fine for water; it'll work for air.
Nice try at the lie, AlwaysWrong, but you've been caught. Again.
You really are as stupid as DimBulb. Look what's above the "3" on
your keyboard.
Sloppy work all around, but then that's just you...
No, you simply can't think, but that's nothing new to anyone here.
DraconisExtinctor
speak."
No, idiot. Noting that what is 50 year old water technology is NOT the
same as modern plastics used on air systems.
You really are slow, dumbfuck.
You are a fucking retard.
Nice fail at reading comprehension, dork boy.
AlwaysWrong,
Not my name, you fucking retard. but you ALWAYS get that wrong too.
You caught nothing. I know more about polymers than a retarded punk
**** like you ever will, AND their applications.
Take your stupidity AND your newfound senility back to the living room
couch, dipshit.
AwlSome Auger
Then show us how, dimmie. The roof is only 9.5 feet off the floor.
You tie off to the floor. Up and over the rafter... Form a loop. Just
enough for you to need to climb up a step or two to put your head into
it..
Better make it at least two though. You'd warp the rafter down enough
that one step wouldn't do the job... lard ass.
DraconisExtinctor
speak."
You're an idiot. Further proven by your pathetic cut-and-paste repeat
of your previous mistake.
I'll spell it out for you, dipshit.
I SUGGESTED PLASTIC AIR LINE for the run.
I ALSO stated that we use it at our workplace and that it is common in
nearly ALL modern production floors and labs.
SO, child, I AM familiar with what IS being used, regardless of your
stupid, jack-jawed idiocy, and your pants down past the asscrack punk cut
and paste retardation. Go back to your hard core senility onset,
dumbfuck.
DraconisExtinctor
dumbfuck.
Correction: Go back to your blatantly obvious hard core senility
onset. Anyone who has seen your posts over the years can see it. it is
so obvious. Sad for you.
You're one stupid shit. PVC *is* used for water. It is *NOT*
recommended for air, as you implied.
<AlwaysWrong blubbering snipped>
DraconisExtinctor
Yes, dumbfuck. *that* is what *I* said. Has been that way for over 50
years, you clueless, AND illiterate fucking DOPE! I was using it at age
eleven helping plumbers build the houses in the development behind my
'70s home. Very likely before an idiot like you even knew what plastic
was. You are a fucking retard.
It is *NOT*
I implied no such thing. I, in fact stated that PVC is the wrong
'solution' for such a task. I even stated so outright. Learn to read.
I even provided a link to proper media, and know more about the proper
media than you ever did or ever will.
All before you started your little piss and moan session you are trying
to squirm away from having fucked up in.
Nice try, you retarded pussy.
DraconisExtinctor
Good Lord, you've taken the AlwaysWrong KoolAid, along with Fields.
Says the idiot that reads "plastic" and morphs it into "PVC".
You are a true retard.
It is *NOT* recommended for air, as you said. Idiot.
Irrelevant, AlwaysWrong. It is *NOT* recommended for air. It's
dangerous.
AlwaysWrong is *always* wrong.
Not only are you wrong, AlwaysWrong. You're a liar. Nothing new
about that, though.
Bullshit.
<more AlwaysWrong drivel snipped>
You are the expert at not thinking.
it's interesting to note that, in an
argument, whenever you come up against the stops because of your
limited capability to use logic and reason - which you demonstrate ad
nauseam - you always revert to ad hominem.
You're funny, Fields. Too bad you're such an idiot. You don't even
know that <shift>3 is "#", even though it's right in front of your
stupid nose.
DraconisExtinctor
Plastic water pipe *is* PVC, moron.
Plastic AIR piping is NOT, you absolute foot right fucking straight
into the mouth dumbfuck!
I never said ANYTHING about using water pipe. EVER. Get a clue,
dipshit.
You implied that it could be used, AlwaysWrong.
dipshit.
You're a liar, AlwaysWrong. ...but you know that as well as everyone
else.
