power opamp?
John Larkin
What's a good medium-power opamp? I need to source/sink at least 60
mA, with say +-7.5 volt supplies, and swing +-6 maybe. No particular
requirements otherwise.
I suppose I could boost a cheap SOT-23 opamp with a couple of cheap
SOT-23 emitter followers....
v+
c
\ +----Rb---b npn
\ | e
\---------+----Rx----+-------
/ | e
/ +----Rb---b pnp
c
v-
but a single part would be nice; I have to do this 16 times on a
smallish board.
John
Eeyore
v+
c
\ +----Rb---b npn
\ | e
/ | e
/ +----Rb---b pnp
c
v-
You like dead bands do you ?
smallish board.
Common up the outputs of 2 op-amps that can drive 30mA though current
sharing resistors.
Graham
Jim Thompson
v+
c
\ +----Rb---b npn
\ | e
/ | e
/ +----Rb---b pnp
c
v-
smallish board.
John
Your suggested approach is probably the least fraught with possible
stability problems.
But when I need lots of near-rail-to-rail swing I put resistors in the
VCC and VEE lines and add the transistors there (e.g., base to VCC
pin, emitter to rail, collector to output point... if you don't need
rail-to-rail, tie OpAmp output to collectors).
...Jim Thompson
John Popelish
v+
c
\ +----Rb---b npn
\ | e
/ | e
/ +----Rb---b pnp
c
v-
smallish board.
Single:
http://cache.national.com/ds/LM/LMH6640.pdf
Slower dual:
http://cache.national.com/ds/LM/LM8272.pdf
Jim Thompson
stability problems.
Like this....
v+
| v+
R |
| e
\VCC----------------------b pnp
\ c
\--------------------+-------OUTPUT
/ c
/VEE---------------------b npn
| e
R |
| v-
v-
...Jim Thompson
Eeyore
John said:
What do you think the 'x' in Rx stands for?
You'll still get a nasty kink in the transfer characteristic.
Graham
John Larkin
stability problems.
...Jim Thompson
Yeah, that's neat but harder to analyze for stability. One would
*really* have to trust the Spice models, or test the heck out of it.
I can imagine way too many oscillation modes!
We recently did something similar, using opamp supply currents to
drive transistors sort of like that, but current-mirror mode, to turn
the opamp into a fairly precise current source. The sim we did didn't
work at all, apparently because the opamp model doesn't actually pull
current from the rails!
John
Jim Thompson
If you tie "Output" back to the OpAmp out it resolves to just a
compound follower.
John
Spice models can be treacherous, which is why I roll so many of my
own.
...Jim Thompson
Joerg
John said:
The 8272 looks good, especially so since I'll be essentially driving a
bypassed power rail, and it doesn't mind capacitive loads. It's $1.30
at 1K, but it would save me a lot of parts, 16 times. Boosting a small
opamp into a bypassed load would add, say, 7 more parts.
You can't use a regular amp with biased npn/pnp into the rail and then
sum the 16 others into its input?
16 x 7 = 112!
Why not? I once had to cram over 50 parts onto the size of a standard
40c postage stamp. Now wait, that'll be 41c soon. 0201, SC75, oh what
fun to debug.
Joerg
If I had trusted SPICE every time many of my design would not exist
today. Can't remember the last time I fired up SPICE. Some time last
year I guess.
Jim Thompson
year I guess.
But you aren't building a very complex structure from individual
devices. My chip designs are almost always way over 1000 devices.
...Jim Thompson
Joerg
True. However, some designs are, let's say, highly unorthodox. For
example SPICE often isn't very useful when you have to use the
saturation behavior of a custom-mix ferrite as a design parameter. Or in
detecting and handling mode jumps of a laser diode. Or mapping sound
wave reflections from a biopsy needle in a diseased area of human tissue.
Tim Williams
fun to debug.
It sounds like, pretty soon, you and Jim are going to have to
collaborate -- your scales of construction are constantly converging!
Tim
John Larkin
Anybody got decent models for ferrite beads?
John
Jim Thompson
On Sun, 02 Mar 2008 14:55:02 -0800, Joerg
[snip]
John
I seem to recall seeing one... maybe Google ?:)
...Jim Thompson
