Shane Kirkman
- Jan 1, 1970
- 0
Hi Doe's anyone know of a adjustable power supply circuit for a 12v
soldering iron.
Cheers Shane.
soldering iron.
Cheers Shane.
soldering iron.
Would A transfomer out of a 30 year old HMV tv be any good. It has 2x12vPhil Allison said:"Shane Kirkman"
** IME 12 volt irons need every bit of heat they can muster.
Use a transformer with taps at 10, 12 and 15 volts like the DSE M2156.
Or, use a halogen light stepdown - electronic style if you like for
very light weight.
.......... Phil
Mate, if you are just learning I'd keep away from mucking around with theWould A transfomer out of a 30 year old HMV tv be any good. It has 2x12v
2x6v 0v 2x110v.
Is a 12v iron controled by voltage or current. I am only learning
electronics.
Mikegw said:Mate, if you are just learning I'd keep away from mucking around with the
mains stuff for the time being. It has a habit of making you dead. Can you
get hold of a mains operated soldering iron? They are not that expensive
can be got from most places.
If you are begining I think it will be safe to say that the lack of a
temperature controlled soldering iron will not be the biggest of your
worries.
Mike
