power supply circuit
vead
Nov 27, 2011
473
transformer connected to half wave rectifier circuit with 50 ohms load
given
primary turn Np = 5
secondary turn Ns=1
peak voltage Vp= 220
load Rl= 50 ohms
find out unknown value
primary voltage ?
secondary voltage ?
I dc current ?
I ac current ?
peak current ?
my effort
formula
Np/NS=V1 / V2
5/1=220/V2
V2= 44 volt Ac
how to determine I dc current I ac current ?
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
given
primary turn Np = 5
secondary turn Ns=1
Do you mean primary voltage Vp = 220V AC RMS?
Or does "peak voltage Vp" mean the peak voltage at the primary?
If it means the peak primary voltage, you should convert it to an RMS voltage, then do the rest of the calculations using RMS voltages, because in circuits using sine waves, AC voltages are normally expressed as RMS voltages.
load Rl= 50 ohms
primary voltage ?
They are probably asking for the primary voltage in VAC RMS.
secondary voltage ?
I dc current ?
I ac current ?
peak current ?
my effort
formula
Np/NS=V1 / V2
5/1=220/V2
V2= 44 volt Ac
That's the right idea, but if the primary voltage is 220V peak, that will be wrong. A voltage of "44 volts AC", without any other information, means 44V AC RMS (root mean square). This is not a peak voltage. If the 220V primary voltage is actually the peak primary voltage, you need to convert that to an RMS voltage first. Then you can work through the calculations again using RMS values everywhere.
DC current will be zero because the positive current on the positive half-cycles is balanced by the negative current on the negative half-cycles. Unless I'm missing something. I think that's a bit of a trick question.
You can calculate the RMS current in the secondary using Ohm's Law if you know the RMS voltage across the secondary and the load resistance.
Once you know the RMS current in the secondary, you can calculate the peak current.
vead
Nov 27, 2011
473
that means i have to convert peak voltage into rms value then I can determine dc current and AC current
vead
Nov 27, 2011
473
look at this in another
transformer connected with 50 ohms load
primary voltage Vp= 220 RMS ac
secondary voltage Vs= ?
primary turns Ns = 5
secondary turns Np= 1
primary current Ip =?
secondary current Is ?
formula
Vp/Vs=Ip/Is=Np/Ns
for secondary voltage
Vp/Vs= Np/NS
220/Vs=5/1
Vs = 44 volt rms
for secondary current
Is =Vs/Rload
Is= 44/50= 0.88 amp rms Ac
for primary current
Vp/Vs=Is/Ip
220/44=0.88/Ip
Ip= 0.176 amp rms AC
know we know following things
secondary voltage Vs= 44 volt Rms Ac
primary current Ip = 0.176 amp rms Ac
secondary current Is = 0.88 Amp rms Ac
please check out someone that above calculation is correct or not , If its correct then I want to add another component diode (halfwave rectifier circuit )
now I think I have to determine dc current how to determine DC current ?
The calculations seem reasonable.
vead
Nov 27, 2011
473
Apart from
which, if I'm not completely mistaken, should read
Vp/Vs=Is/Ip=Np/Ns
yes you are correct It was my mistake
now transformer connected to half wave rectifier circuit with 50 ohms load
I want to determine dc output current and dc output voltage
output dc current Idc= 44/50= 0.88 dc current
how to determine output dc voltage ?
I think it will be 44 volt dc
It depends on what the primary and secondary turns are.
You had
if the primary turns are 5 and the secondary turns are 1, then your calculations are correct (your nomenclature is wrong, but amazingly they cancelled out).
I just did the calculations in my head and estimated the answers and got the same as you. I ignored your nomenclature.
vead
Nov 27, 2011
473
You had
I am little bit confused about dc current and dc voltage
how to determine dc output voltage?
then I want to add capacitor (filter circuit)
vead
Nov 27, 2011
473
can someone please tell me how to determine dc output voltage ?
14,290
This page describes the operation and the theory for a half-wave rectifier. Use the equations given tehre.
KUMARA SHP
Aug 1, 2014
122
DC voltage is basically the RMS value of the AC voltage
now you have half wave rectified sine wave , in half of period it is sine wave which has RMS value which you had calculated & other half of period it is zero, so current though load is varie with time, you may have to find average current or get equal RMS value & divide it from load value,
google to find equation for find RMS, you can easily find
vead
Nov 27, 2011
473
transformer with load
transformer connected with diode and load
(given data )
unknown data
Dc current
dc voltage
for DC current
Idc= Vs/RL=0.88 dc current
For dc voltage or output voltage
Vdc= Idc.RL
Vdc= 44 volt dc
check out this value and tell me its correct or wrong
vead
Nov 27, 2011
473
(given data )
unknown data
Dc current
dc voltage
for DC current
Vdc= Idc.RL
Vdc= 44 volt dc
please someone check out this value and tell me its correct or wrong
