Power Supply Pin-out help needed. Pics included!
Treydogg77
Jan 17, 2012
6
I bought a Altec-Lansing ACS340 Computer Speaker Set. I need the pin out for the odd ball power input. I know it requires 12v 8ma and was going hard wire the board but, I don't know which side is positive and negative. I've got a DVM whats the best way to find the + and - with it? Pics of the board are below.
Thanks for any help!
My guess is that it's an AC , centre tapped input, probably far more likely to be 800mA or 1.8A than 8mA.
There's almost always something written near the power connector
OK, it's 13VAC 4A -- and it's centre tapped. look here.
Treydogg77
Jan 17, 2012
6
Thanks Steve! Please bear with me im a newbie... I've checked all kinds of websites but all of them are sold out. I have a handful of power supplies I check them for the correct voltage. Whats centre tapped and how can I tell which pin is positive and negative?
Thanks for helping me out!
There is no positive or negative.
the wires leading to the rectifying diodes are the two "ends" of the AC supply from a transformer (and can go either way around). The centre tap goes to the connection on the board that looks different, i.e connects to a large area of copper.
Treydogg77
Jan 17, 2012
6
So I just need to solder the 2 wires from the power supply to each main input pins on the board and shes good to go?
NO, there are *three* wires.
This device requires a centre tapped 13VAC power source.
Treydogg77
Jan 17, 2012
6
Steve, sorry man im confused. Are you trying to say the centre tap is like a remote wire? The board needs 2 Positives and 1 negative to operate?
Resqueline
Jul 31, 2009
2,848
A 13V center tapped transformer has three wires, all with power, two "hot" (6.5V) and one "neutral" (0V). It would be rectified to + & - 8V, for a total of 16V.
Now, looking at your unclear pictures, & Googling the power supply, it seems to me they're not center tapped, only plain two-wire 13V 4A (52VA) units.
