Power supply with current output
electronicsLearner77
Jul 2, 2015
306
I know that if i have linear power supply of 0 to 5V, i can vary voltage from 0v to 5V. But do we have a power source which gives me current output instead of voltage from let us say 0amp to 5amp etc? I want to buy.
Tha fios agaibh
Aug 11, 2014
2,253
To be clear, You can not have current flow without voltage and a load applied. Enter Ohms law.
If you have a 1 ohm load applied to a 5v power supply capable of delivering 10 amps or more, it will never draw more than 5amps.
If you have a 1 ohm load applied to a 3v power supply also capable of delivering 10 amps or more it will never draw more than 3amps.
If you have a 1 ohm load applied to a 5v power supply capable of delivering only 2 amps, it will not be able to deliver enough current and the voltage will get drawn down to 2v.
That said, current can be limited on a power supply but you can't arbitrary dial in x amps on a dial.
Yes, There are many linear power supplies where you can set the maximum current limit.
There are adjustable constant current output.
I built a small one to charge nicad cells using an LM317 regulator and a 15V dc plug pack.
Output current can be adjusted anywhere from 50mA up to 500mA and from 1 to 8 nicad cells.
shrtrnd
Jan 15, 2010
3,903
As noted by Bluejets, what you want is commercially available, but they're pricey.
Bluejets built one for low current, there may be plans available for your 0-5A needs.
Mine is an old Hewlett/Packard Harrison 6203B but it wasn't cheap when I bought it years ago,
and it'll only do 0-7.5V at 0-3Amps.
If you're just a hobbyist, you might check eBay and see what's out there to save money.
