Power suppy dilemma
dragon
Oct 31, 2022
248
Use ac input and put a voltage doubler on it, thatll give u twice the volts (but amps stays exactly the same, so the effective resistance goes up when the volts do, cancelling out.). And u can light up nychrome wire with low amount of volts, and 5volts/240 or so amps is 18 ohms, perfect for nychrome wire, I wonder if the led's turning electricity into light stops the nychrome from lighting up via transduction, but i have no idea, just leds do strange things to me in the sim I dont know the cause of.
bertus
3,854
That is NOT true, the voltage will be double, but the current will be half.
You can NEVER get more power out of a circuit that you are putting into it.
Bertus
