powering 2 LEDS or Neons from a 240v feed?
cardiffboy22
Sep 10, 2020
Hey all! I’m looking to have 2 leds or neons to run from a 240v mains feed. (It’s to illuminate the display of an old 1940s radio.) Can anyone spread some light (forget the pun) on the best way to do this?
kpatz
Feb 24, 2014
334
Most old radios used small incandescent bulbs to illuminate the dials. If you want the most authentic look, that would be the way to go. Are the original bulb sockets and circuits intact? You'll just need bulb(s) of the correct voltage and size to fit in the sockets. Chances are they're fed from a lower voltage secondary of the main transformer, they aren't running on 240V.
LEDs are best for lower voltage DC applications. They can be made to work on 240V AC but, LED illumination in 1940s radio? I'd rather go authentic and stick incandescent bulbs in there.
Neon would be easy, just needs a dropping resistor to run straight off the mains, but you'll get a dull orange glow and not the warm white incandescent glow.
ramussons
Jun 10, 2014
475
There's a very simple way to use 2 LED's running of mains. Not too sure if the details are forbidden in the forum.
14,280
If you're hinting at capacitive power supplies: not forbidden but strongly dis en couraged.
kpatz
Feb 24, 2014
334
Encouragely discouraged? Discouraged to be encouraged? I would say, "not a good idea for safety reasons". :)
In any case, I'd avoid neons for this application, they just won't look good, plus you'd have to run HV to the bulb locations. There should already be low voltage (6 or 12V) to the bulb sockets, so use that, ideally with incandescent bulbs but in a pinch you could use 2700k LEDs. You'd need to rectify the power (full wave is better) and a decent sized cap to get rid of the 100Hz or 120Hz flickering if you use LEDs, and a suitable current limiting resistor based on the desired current and Vf of the LEDs.
bertus
3,848
When using leds, scratch the leds with some sandpaper to have a wider scattering of the light.
Leds can have very narrow beams.
Bertus
dave9
Mar 5, 2017
1,191
^ Seems like something good to do to the plastic encapsulated type with the rounded focal dome on top. For those, I take a file or sandpaper on a flat surface and completely sand off the dome to a flat top then polish to clear again, but for the surface mount LEDs none of this is needed, though then you need the PCB to solder them to or if star heatsink mounted, still a more elaborate mount (maybe, depends on the structure behind the area needing illumination).
The "best" way to do it all depends on the desired outcome. If looking to restore to original state then you should use same bulbs and it's easiest because the design is build around that. If looking for extreme bulb life (why? Surely that old radio can't be such a pleasure to listen to that you have it running all day long?) then you can tap off any lower voltage circuit, rectify and smooth and current limit LEDs. You could even get one of those long, thin COB style so you have less of a burden spreading the light and mounting it, though most of those put several LEDs in series so need a higher input voltage.
radio-man
Dec 19, 2018
You can get AD/DC led blubs via on line auction site to replace the standard 6.3v bulbs that were fitted original, I do this in some off my vintage radios
DJL33B
Aug 22, 2019
10
I think there were some Really Old Radios (this was many years ago, I am almost 70) that had the dial light(s) in the series string of heaters. The dial lights would illuminate slowly as the heater current stabilized. Changing the circuit would be tricky.
kpatz
Feb 24, 2014
334
...that had the dial light(s) in the series string of heaters...
So if the dial light burned out the whole radio would stop working. Brings a new meaning to "one light goes out, they all go out!"
