then useing a green scara or pot scrubber, not steel wool, clean down the shiney side, this will remove that clear layer, use some jiff or ajax to do it. this will enable a fine piont marker pen to take to it then . then place an ic mounting board onto it , and useing the fine piont marker , poke it through each hole in the ic mounting board, to mark the pin positions of that board , onto the alliuminium square, then remove the ic board and, use i fine shark pionted object , press a hole into the alliuminium where each dot is, this for when you use a mini circuit board drill to drill the holes .
now drill every hole out, then after that increase the drill size and redrill so the holes are bigger by looking at these pictures here you will get it. now use this predrilled alliuminium square for circuit board designs if your useing intergrated circuits , and once youve done the drawing useing this alliuminium template all you have to do is use the dalo pen and if you do it right you will get it then , then useing a nail sharpened to a long piont, you use that to punch the hole in the middle of each dot where the intergrated circuit pinns go through , allso i have a plastic home made electronic component leg spaceing template for drawing circuits with for printed circuit boards , ill add this latter and i use it to draw the corect component leg spaceings so that when i drill the board after etching the components will fit perfectly through the holes
