audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
When Mosfets are used for pulse-width-modulation to control a motor's speed, they switch on and off at up to 100kHz. Then a gate current of up to 1A from a Mosfet driver IC is used to charge and discharge the high gate capacitance quickly. The Mosfets are heating for the time that they are not completely on or off, so the quicker they switch then the cooler they will be.
A 1/4W resistor will be extremely hot at 1/4W and will overheat unless it is in free cool air. On a pcb it is not free because the pcb and parts near it block air flow. So on a pcb its max dissipation is about only 200mW when it will be extremely hot. At half its rated power it will be hot but not too hot on a pcb but it will last a long time and parts beside it won't be damaged.
The Mosfets you selected are old and have a fairly high on-resistance which reduces the max speed and max power of your motor.
