problem programming pics
gatoulisss
Jan 23, 2015
36
hello,
i have a problem with programming my pic microcontrollers...
im writing a very simple code just to test them
the programm is about to blink a led. in the simulation the programm running just fine also on the compiler no problems at all the programmer says that the programming ends succesfully but on the circuit nothing works.
i have test the same program in 5 diferrent pic (3xpic16f84A, 1xpic16f88, 1xpic16f628A) microcontrollers and i have the same problem any help?
i upload some fotos of the situation.
Arouse1973
Adam
Dec 18, 2013
5,178
Hello
You don't have a pull up resistor for your reset line. The Pick kit 3 may be holding it in reset but even if it is not, a resistor is needed to allow the program to run. Look at the data sheet for the PIC to see the recommended circuit. It's normally a capacitor and a resistor.
Are you running in RC mode? It's just I can't see any oscillator circuitry. You should also have support and decoupling capacitors as close to the PIC power pin as you can. Google this to see how it's done.
Your resistor looks like it's connected differently to your drawing which as it is you will put the output into current limit if the output is set high, this might be ok for some LEDs but we would normally use a resistor to save power because you generally wouldn't need it that bright as an indicator. Also check the resistor value and tell us what it is....... 330R?
It looks like your design has fixed this issue but your drawing hasn't been updated. Just check your code to make sure you are setting the output high.
I can't see the LED connection so you will have to double check that.
You could post your code here for the other guys to look at, they may see something wrong with it.
Adam
You need to set various configuration options in any PIC project. As Adam hinted, the oscillator selection is often external RC for PICs. You need to select the internal oscillator. Also you need to turn off the watchdog timer in configuration settings.
I am at work now and do not have MPLAB installed, when I get home I can probably give you the configuration settings needed for one of your PICs.
Arouse1973
Adam
Dec 18, 2013
5,178
Good one Bob!
Adam
gatoulisss
Jan 23, 2015
36
ok thanks! that would help!
Hello
Adam
the code is this
void main() {
trisa1_bit=0;
for(;; ){
porta.f1=1;
delay_ms(1000);
porta.f1=0;
delay_ms(1000);
also i have the internal oscillator on and watch dog off
Arouse1973
Adam
Dec 18, 2013
5,178
At work Bob. Thought you were a man of leasure. If not tell the wife to cut down on handbags lol.
Adam
Adam
Almost, retiring at the end of April.
And despite our quite reasonable income, my wife shops mostly at consignment stores. Though she does have a weakness for 5-star hotels when we vacation.:)
gatoulisss
Jan 23, 2015
36
i use same code same bread board but different microcontroler, pc and compliler and it run just fine...so the code is ok,there is something wrong or with my computer or programmer(just bought it) or pics
CDRIVE
May 8, 2012
4,960
Hey Guys, don't let this just end here. There are members out here (including me) following these threads with the hope of learning PICs through stray coupling.
Chris
