Problem with 2.8 -> 5V power supply
jozef007
Nov 9, 2019
28
I having problem with power supply, which for inputs from 1.8 - 2.8 V should generate 5V on outputs.
Currently I don't have load on output, I just measured voltage there, which was around 1.5V and circuit TPS61032RSAR started overheated, current on input was 440mA. I tested thoroughly all 16 pins, there was not a issue. Can some please look into, not sure, what I'm doing wrong. I attached schematic, bellow is link for IC. Thx
http://www.ti.com/lit/ds/symlink/tps61030.pdf
  • Schematic.pdf
Alec_t
Jul 7, 2015
3,821
Welcom to EP!
Try adding a nominal load, say 1k, and measure again.
jozef007
Nov 9, 2019
28
Welcom to EP!
Hi Alec, I try it but result is the same. Can you please assess if my schematic has a merit? I calculated parts, want to be sure, that they are correct.
Alec_t
Jul 7, 2015
3,821
Your circuit may be oscillating uncontrollably.
I don't see the 100nF decoupling cap (as recommended in the datasheet), which should be directly across the supply pins of the IC.
Does your circuit layout follow the datasheet (section 13) recommendations? Hopefully the circuit isn't on a breadboard!
jozef007
Nov 9, 2019
28
I used SMD's so whole board was designed, hopefully we are talking about same stuff but I have 10uF as C2 for such function (as per TI documentation Fig. 19).
Here is PCB footprint (C2=C32, R3=R22, R7=R25,C9=C5,C23=C3)). C2 is on input. Maybe something I'm missing here? Thx
bertus
3,882
In the layout in the datasheet there are not such small traces.
They use complete planes for the connections.
They also show where vias are planned:
Bertus
jozef007
Nov 9, 2019
28
Bertus
Thank you for guidelines, but is such change, via way how I did PCB, effect so much function? I don't have so much knowledge to explain it...
Hunter64
Nov 20, 2018
51
"As for all switching power supplies, the layout is an important step in the design, especially at high peak currents and high switching frequencies. If the layout is not carefully done, the regulator could show stability problems as well as EMI problems."
Just a quote from the datasheet mentioned in the first post.
jozef007
Nov 9, 2019
28
Word is around, that I need to pay more attention to the documentation... Must admit, they are some improvements need to be done :)
Let's assume that I will follow PCB footprint to the letter, otherwise there is not visible issue in schematic itself? Just reminding that I will have input 1.8-2.8 V and output 5V with expecting load max 1.5V. Thx
jozef007
Nov 9, 2019
28
I get verified that schematic is correct. I will create new PCB layout and hopefully will work. Thx for assistance. I'm concluding problem as resolved.
