Problem with Clamp Meter (Benning)
redoomed
Nov 4, 2016
Hello guys!
I have a digital clamp meter (Benning CM 1-2, I have uploaded two photos of the pcb board) and it has two problems:
1. The Clamp meter's two cables are disconnected from the PCB board and I don't know where exactly to solder them. However I have seen two possible pins on the board (I marked them with a red circle) that might be the right place for the two wires
2. The device does not turn on. Even with new batteries, when I turn it on nothings happen in the screen.
I have uploaded two photos. Have you any idea?
Thank you very much in advance
I would hazard a guess that they connect to the wires coming from the "jaws" of the clamp meter.
Surely there are 2 wires somewhere that are not connected to anything?
kellys_eye
Jun 25, 2010
6,512
Did you insert the batteries correctly? Sure they are new/charged?
The circled connections are for the clamp.
Looks to me as if there is corrosion between some of the processor pins. There's also a dodgy soldered link beside the red connector - potentially indicating the track 'blew out' under previous fault condition and has been soldered back in place..... sure this meter isn't 'used' or from a dodgy source?
