I have a problem with my DSC 832 PC5010 v2.0 system with 3 LCD5501Z keypads. I installed and programmed this system in my home 20 years ago. I set it up to call my cell phone and my wife’s cell phone via our home magicJack phone system. It has worked for 20 years without a problem until recently. Actually, only had a few alarms over those years for faulty smoke detectors. I test the system about every 6 months to verify correct operation and the phone calls to our cell phones. The problem now is it will not call our phones. We have 2 portable phones attached to the magicJack and they work fine. If I instigate an alarm, the magicJack acts like it senses the alarm system and is waiting for the touch tones just as if I use a portable phone and push the talk button before inputting the number. But no touch tones are indicated on the magicJack window on the computer. The TLM system does not indicate a problem unless I disconnect the phone line.
I made the assumption that the DSC 5010 panel had failed and found a old stock new panel on eBay. I installed the new panel and programmed same as my original programming from 20 years ago. The new panel acts exactly the same – all functions work except the calling. It seems unlikely that both panels have the same problem, so hoping that someone can suggest a solution.
Here is my coding pertaining to the phone calling:
015 1 2 4 7 on
160 002
310 1111
320 11 11 11 11 11 11 11 11
321 11 11 11 11 11 11 11 11
360 03 (not sure why I did not use 05 originally, but 03 worked for years)
361 1 on
365 1 on
380 1 5 on
301 XXXXXXXXXX (phone number only)
303 XXXXXXXXXX (phone number only)
Even though this programming worked for 20 years, I also tried various HEX “D” *4*, “E” *5* and “F” *6* digit additions to these phone numbers with no change noted. I did power down and restart the panel each time as it has been noted that a power down and restart procedure may be needed on some of the DSC panels to accept the phone number change. The HEX additions do cause the “Post Dial Wait Time” to increase over the preset 40 second wait before an attempt to redial takes place (about 2 seconds per HEX digit). With 2 phone numbers and 2 dial attempts programmed, there are 4 dialing attempts, all with no touch tones indicated on the magicJack window. The house phone line does get dropped (phones show “no line”) during all the dialing attempts so the DSC 832 does appear to be trying to make the calls.
Can anyone who knows these panels tell me if I have tried everything?
015 1 2 4 7 on
160 002
310 1111
361 1 on
365 1 on
380 1 5 on
