Hello
I have two amplifiers, one of which had a problem with the output relay and I changed it. But I noticed that one channel hums weakly, and the other more loudly.
After swapping the terminals to the preamp, the hum moved to the other channel.
When I tested with an audio signal, the hum comes from a component mounted in the feedback of the input TL082 (opto-resistor) and the closer my finger is to the housing of this element - the hum intensifies, if I touch it even louder it hums.
It serves if the input level is too high - to limit the signal (indicated by an LED)
How to remove this buzzing (if there is no applied voltage to the optocoupler - the output shows infinity, if there is an applied voltage - the output shows 300k ohms)
The other phenomenon
when there is an audio source connected - and the potentiometers are at a minimum - the outputs of the amplifiers play weak music.
