Problem with Synchronous Motor
Hammerhorror
Apr 19, 2016
13
Hi
I have a globe light. One that has LEDs inside, and a Synchronous Motor. It was dropped on the floor, and the shaft from the Synchronous Motor was damaged. I've bought a replacement Synchronous Motor, connected it to the circuit and it doesn’t work. I have even tried connecting it straight to the 6v AC. Still nothing. You can feel an initial restistence in the motor every time it’s connected to the power, but still it doesn’t rotate. I have four of these motors, and get the same result from all four. I can only guess that I’m doing something wrong.
Any advice please would be appreciated.
Minder
Apr 24, 2015
3,560
More info on the motor would help.
Part No.
Pic etc.
M.
Hammerhorror
Apr 19, 2016
13
It’s a
TYC-30
AC 6V
50/60Hz ROHS
5 rimin 1-1.5
CW/CCW
The same specs as the original motor, only it has a different model number. Couldn’t find the original anywhere. The ones I have came from China
Minder
Apr 24, 2015
3,560
Is that is only 5rpm, were you expecting it to rotate a high speed perhaps?
M.
Hammerhorror
Apr 19, 2016
13
No just slow. So it rotates the lens, making the light from the LEDs rotate around the globe
Minder
Apr 24, 2015
3,560
So it is not even turning at 5rpm?
It looks like a simple timer motor with just 2 connections,
Sure you have the right voltage?
They usually have a small internal 'kicker' to start it off in one particular direction.
M.
Hammerhorror
Apr 19, 2016
13
Yeah
The globe is 6v. Even when I try 6v, direct from the adaptor, nothing. All you can feel is a slight resistance, but no actual turning.
What is the supply voltage reading?
Sounds like no power.
Where did you get the "straight from 6v ac" adaptor?
Perhaps show a few pics.
Seems it will spin either direction and the "friction" you feel is probably just the gearing.
