Programmable clock divide-by-N
Thomas Magma
For some reason I'm having troubles finding a programmable clock divider
chip. I have a 20MHz reference clock that I need divided by 23. I would like
the option of changing this divide ratio if needed. I can't seem to find a
simple single chip solution (smaller the better). I'm currently looking at
CPLDs which is not a clean solution because of ICP. The 40103 is another
option but is border line with the max speed vs my operating voltage. I'm
also looking at using the R or N counters of a synthesizer chip if this is
at all possible.
Seems to me there should be a two wire programmable SC70 divide-by-N
available, but I can't seem to find anything close.
Any thoughts?
Thomas
Thomas Magma
Not SC70 but the On Semiconductor Fxxxx chips are really nice to use with
two-wire variants available.
Thanks Brendan, could you elaborate on what series the Fxxxx is? I'm having
a hard time finding it.
Thomas
pimpom
divider chip. I have a 20MHz reference clock that I need divided by
23. I would like the option of changing this divide ratio if needed.
I can't seem to find a simple single chip solution (smaller the
better). I'm currently looking at CPLDs which is not a clean solution
because of ICP. The 40103 is another option but is border line with
the max speed vs my operating voltage. I'm also looking at using the
R or N counters of a synthesizer chip if this is at all possible.
Any thoughts?
Thomas
Is the 54/74HC4059 any good to you?
Thomas Magma
I originaly looked at the 4059 but can't find this chip in a fine pitched
package, it's too large for the project. I was also hoping for some sort of
serial interface so I'm not using up unnecessary pins on my micro.
Thomas
Jasen Betts
buy a micro with extra counter and use that
that'll only use 2 pins (worst case: if you need an output and the
20Mhz input is different from the chip's clock)
--- news://freenews.netfront.net/ - complaints: [email protected] ---
