Programmable Voltage Source Idea
http://i38.tinypic.com/2qidapt.jpg
Will the above circuit work well in practice for a programmable
voltage source? The zener would be a similar idea to shunt the current
for over-voltages. I am in need of a medium power programmable voltage
source and this seems to fit the bill while being simple.
Joe
James Arthur
D said:
wtf????
How come this circuit looks bogus to me???
It's sideways. All the electrons will fall out the
bottom.
James Arthur
James Arthur
Jim said:
And didn't they leave out the rotating magnets ?:)
...Jim Thompson
Yes, great catch. They did leave those out--and that's
the tie-in to mpm's free energy machine, the centerpiece
of our new green/renewable feelings-based energy agenda.
Cheers,
James Arthur
David L. Jones
You left out lots of important starting detail like:
- how you want to "program" it
- what voltage range you need
- what you mean by "medium power"
That circuit is silly BTW.
"Abstract Dissonance" - we haven't seen you here in a while...
Dave.
James Arthur
Joe
Okay, you haven't gotten many straight answers, so I'll
take a stab.
No, your circuit won't work. The LM339 is a comparator;
it'll oscillate in that circuit. The MOSFET might
oscillate too.
You can use an LM339 as a lousy op-amp, but it'd be
better to just use a decent op-amp. Or an LM317.
You'd get more sensible answers if you showed input and
output nodes and said something about your goals
and needs (accuracy, range, power output, load, etc.)
HTH,
James Arthur
Dookie
take a stab.
oscillate too.
HTH,
James Arthur
Well, I figured since you guys are so intelligent you would be able to
figure out what is going on. It is suppose to be a comparator and not
an op amp. It is not a difficult circuit to understand. Seeing how
rude the people are here it's not even worth trying to explain. I'll
come back in another two years and maybe the trash will have been
taken out. If anyone can't figure out the circuit then maybe they need
to go to sci.electronics.basic and hang out for a while. The circuit
works fine in practice and I'm not sure what your talking about with
oscillation. The comparator should oscillate to some degree and with a
bit of built in hysteresis it should be fine. Do you seriously thing
that the opamp/comparator matters? That alone tells me either you guys
don't care to pay attention and just want to be jerks. I used the
lm339 because that is what multi-sim had. Abstract thinking is
important but I guess they don't teach that in repair school? See you
guys in two years, hopefully you will have grown up by then.
James Arthur
It actually is difficult to understand.
I don't understand how a 10k pot will handle 100 volts
without burning up, or why a circuit that's supposed
to be programmable doesn't have a programming input.
Or an output.
I don't understand why you'd think that the LM339 has
built-in hysteresis--it doesn't.
I don't understand why the apparent reference input to
this voltage regulator from hell is nailed to +5.5v,
which makes the whole thing look kind of useless.
I don't understand why you're using such a complicated
circuit to perform such a simple function so poorly.
I don't know why you had to go to all this trouble
just to fry a pot and a zener diode--is it a race
perhaps? To see which one will smoke first?
But that's just me.
James Arthur
James Arthur
(sci.electronics.basics added, at Dookie's suggestion)
Or an output.
I don't understand why you had to go to all this trouble
just to fry a pot and a zener diode--is it a contest?
A race to see which one will smoke first?
But that's just me.
James Arthur
James Arthur
D said:
I don't understand the person..
If I can't understand the person, there's a good chance I won't
understand the circuit either.
D from BC
A schematic reads like a window into its author's soul.
You can understand a lot.
I don't understand someone asking for critique,
then complaining when he gets it.
Cheers,
James Arthur
MooseFET
If it works fine in practice, why did your original post ask us if it
would work in practice? It's really goofy, but I suppose it might
regulate. Some.
Bye. See you in 2010.
I really liked the 0% pot and the "virtual diode". I looked in
digikey but they don't stock them. You make a nice 0.2V step
controlled supply like this.
------------------ To CD4051 Vcc and X7
!+\ LT1498
+------------------ To CD4051 X6
!+\ LT1498
+------------------ To CD4051 X5
......... Repeat 6 more times .....
Try it in LT Spice
Archimedes' Lever
Cheers,
James Arthur
Yeah... you can call it the Obaminator.
ehsjr
Cheers,
James Arthur
Yeah, but if they included them, the damn thing might
work, and we'd need a new unit of measure: Obamawatts
Obamawatt: the result after Obama taxes the shit out
of you and runs the money through his snake oil crapology
policies; analogous to the circuit at
Ed
James Arthur
Ed
Now Ed, I think you're being overly pessimistic.
Why, I was driving home yesterday when I noticed my
fuel gauge had crept up from "E" to about 1/16th.
Then it hit me: "It's already working! Obama's filling
my tank!"
Cheers,
James Arthur
ehsjr
my tank!"
Cheers,
James Arthur
Ben Bradley
without burning up,
That one's easy, it's a virtual potentiometer, so it has an
infinite heat sink.
James Arthur
infinite heat sink.
Thanks, that explains it. Now how about when R5 is set
to, say, 100 ohms--how does that work?
Grins,
James Arthur
James Arthur
John said:
That comparator pointing up is like a raised middle finger.
John
Yep, that's how I took it.
No one's pointed out that the regulator-oscillator
loop never does anything useful: D1 never conducts.
Well, at least not until after R5 smokes...
Best,
James Arthur
ehsjr
Grins,
James Arthur
Well, D2 and R1 are made out of strongium, maybe even
virtual strongium, so ~8mA for the R or 1 amp for the
zener or even way higher won't hurt either one. As to
D1, it depends upon how virtuous it is, but that's
not specified, so for diminishing values of virtue,
the circuit gets dirtier and dirtier.
Ed
