Programming a stepper motor with Picaxe
Chaymoss
Aug 18, 2021
3
Code:
#picaxe 28x2
main:
let b1 = 0 ; set b1 value
low B.2;
low B.5;
FOR b1 = 0 TO 1000
    high B.0 ; switch on output B.1
     pause 500 ; wait 0.5 seconds
     low B.0 ; switch on output B.1
NEXT b1
pause 1000; wait 1 seconds
high B.5;
FOR b1 = 0 TO 1000
NEXT b1
goto main
I need some help for programming the stepper motor "https://docs.rs-online.com/9cd2/0900766b813f0a12.pdf" with PICAXE-28X2 SHIELD BASE "https://picaxe.com/docs/axe401.pdf", the driver that I'm using is STEPPER 4 CLICK "https://www.digikey.at/htmldatasheets/production/2455715/0/0/1/mikroe-2748.html"
The motor does not work.
You can see the program above.
Thank you in advance
14,312
How is the stepper driver connected to the Picaxe shield (B.0, B.2, B.5)?
What are the settings of the stepper driver?
How is the stepper driver connected to the motor?
Chaymoss
Aug 18, 2021
3
As shown above in the pinout digram, I used B.2 to connect to ENABLE, B.0 connected to STEP trigger (PWM) and B.5 to DIRECTION, and RST connected to the reset of picaxe shield so I'm wondering if this is the right way to program the outputs pins in PICAXE Programming.
I checked the electric circuit, everything is working right supposedly. However, I think the problem is in the programming, cause it's my first time I'm using the Picaxe shield, and I couldn't find programming examples that are compatible with PICAXE-28X2 for stepper motor control.
Sunnysky
Jul 15, 2016
577
Does the USB port work? I was impressed with my setup with open windows software Gcode Panel to an UNO with a $24 CNC shield on a 12V supply . Using gcode downloaded to UNO and Gcode Panel on a laptop. Watch out for motor supply ground noise if connected to an earth grounded tower interfering with USB port cable. Very nice User interface for XY control of acceleration, max speed and position recal with home switches. Uses touch jog buttons or user programmed Gcode files to run any pattern.
Chaymoss
Aug 18, 2021
3
Thank you Sunnysky, I tested the USB port, the picaxe cable, and the Picaxe base shield, they are all working.
