Audioguru,
I have to give you guys credit that you can get any of this stuff to work. I have spent loads of money, buying electronic components, resisters that are of varying values, and having to guess as to what the wattage should be as none of the schematics I have seen either for the LM386 or the Motorola amp give a resistor watt rating. I bought all of the lower ones (1/4, 1/2, 1). I tried the LM 386 with this toy chip, got it to work one night, busted the little pot, and have never been able to reproduce the clear amplified sound I had again. I never bothered to try the 9 volt split you posted on the breadboard because I can't get anything else to work - so why bother?. I then went out and spent more money on more resistors, and more capacitors because every schematic one finds on the web for these chips have different component values. I tried this Motorola MC34119 headphone amplifier which is equivalent to a NJR NJM2113 (Mouser Part # 513-NJM2113D), and I can't get this thing to make any noise! I have looked for more schematics, and out of the three I found, all three are different. After all this is said and done, I should have just went to the local college, found an electrical engineer, gave him the chip from the toy, and paid the guy to solder a few working amplifier boards together for me. The LM386 was disappointing, but this MC34119 really has me irked because it is supposed to run off a voltage as low as 2, and it doesn't do anything. I even searched and found this silly 39 ohm resistor to put in line with the output to power the 8 ohm speaker.
Bruce
