darren adcock
- Sep 26, 2016
- 463
- Joined
- Sep 26, 2016
- Messages
- 463
Why have you gone to the bother of mounting your transformer on a sub chassis?
I don't have acces to your C:\ drive and on mine I can't find the pdffile:///C:/Users/User/Downloads/Instructable%20-%20Assembling%20a%20series%20lamp%20limiter.pdf
That should be o.k., just not visible on the photos. Just for safety a double insulation (2 layers of shrink tube) is what I recommend.The gry and purple wires are soldered and then shrink tubed (but used clear shrink tubing).
Flippin eck I'm doing well on here today, where's that IT job ;-)I don't have acces to your C:\ drive and on mine I can't find the pdf
Really much better!Here is a better one
That looks OK. I put a switch across the light so that I do not have to remove the device when full power is required.
You have the plug labelled wrongly, looking at the BACK of the plug where the wires are connected, the neutral is on the left. We used to say red to the right but they have changed red to brown which doesn't scan so well.
Hi Steve.The lamp should be in the active line.
Connect the Earth too.
If the plug was inserted in the socket of the lead you are making, like pins (i.e. mating pins) should connect.
Portable devices should have mains double pole switching.
No idea what the "enclosure" around the transformer is supposed to do.
Earth lug should have a star washer to stop it coming loose.
Actually no idea why there is an "angle lug" at all, can easily break where sharp bend(no radius) has been made.
Black screws not normally used for earth.
Hope there is a terminal and screw to attach the earth and not just looped in like in the photo.
I also realise I haven't checked to see if where I am planning the PSU to go in my synth is ok. As far as i can understand the most sensitive circuits in the synth are the oscillators (they are temperature controlled with a dual pair of transistors) so i have them on the opposite side from the PSU. View attachment 39605 View attachment 39605 View attachment 39606 View attachment 39606I recommend you use a ring cable lug well fitted to the wire and securely screwed to the metal housing.I can change it and make a flat lug
Thanks Harald. I will order this todayI recommend you use a ring cable lug well fitted to the wire and securely screwed to the metal housing.
Without the proper tool the usual crimp connection is not possible. you would have to resort to a soldered or screwed lug. Here are some ideas and tips. Something like the single conductor lug on page 16 is suitable.
Is the active line "Live"?
