Hi all, currently puzzling over why this PSU is outputting nothing, I can not find a schematic for the PSU or even it's transformer a BCK02, the transformer has 4 inputs on the hot side & they are getting 78VAC each across the 2 central pins & the 2 outer pins, without a pin out/schematic that's how I'm guessing it's fed, is 78VAC enough?
The main 68uf 400V cap could be suspect but I do not have an ESR meter nor does my Fluke 10 have a capacitor test function, looking at it the cap top is slightly domed but not to excess, when powered the cap is fed 230VDC which drops to 8VDC the instant the juice is turned off, IMO far more residual charge should be held for longer in this cap, what are you're thoughts?
Here are some pics of the offending PSU for you're viewing pleasure
Any assistance fixing this greatly appreciated
