On Sun, 11 Oct 2009 01:38:30 -0400, "Michael A. Terrell"
:Ross Herbert wrote:
:> You post under the name of Andrew Edge yet you sign as Martin. Surely, if you
:> really worked at MSW Systems
http://mswsystems.com/home.htm you would have
your
:> own email address there. Incidentally, there is nothing on the MSW website
that
:> lists one of their services as "Public Address System Design". The stated
main
:> areas of services are "Systems & Networking, Web Design and Business
:> Apllications" which says that they are merely engaged in IT design and
support.
:> This is a far cry from the engineering requirement required for a valid
company
:> experienced in PA system design. Of course, they could simply have failed to
:> enter this function in their services lsting....
:> I will be querying management at MSW as to your bonafides...
:> It is plainly obvious to anyone who is experienced in electronics that you
are
:> not an electronics or PA engineer or anything like it. You say "you don't
have
:> as much time (as those of us who may be competent in the field) to give
:> explanations", and that "there is more fun in life than debating on these
:> issues".
:> These two statements give you away as a fraudster and would NEVER be used by
:> someone engaged in the PA design field. In fact, they are statements more
likely
:> to come from an uneducated juvenile out to cause trouble. Anyone who was
:> seriously involved with the design of PA systems, as you claim to be, would
have
:> at the very least, a knowledge of electronics building blocks and how to
select
:> the appropriate items for the project at hand. You plainly don't possess this
:> knowledge otherwise you would be pleased to describe in complex detail the
:> environment you have to work with and the specific problems which this
:> environment might present in coming to the best solution. That is the real
:> reason why you can't be bothered to provide explanations.
:> There are myriad problems in designing a PA system and there is no person on
:> this earth who can supply you with the answers without ALL of the
specification
:> and details. It is a specialised field which does not really fit in with "IT
:> Consulting".
: His IP address resolves to Italy:
:IP Information - 82.84.149.167
:IP address: 82.84.149.167
:Reverse DNS: ppp-82-84-149-167.cust-adsl.tiscali.it.
:Reverse DNS authenticity: [Could be forged: hostname
pp-82-84-149-167.cust-adsl.tiscali.it. does not exist]
:ASN: 8612
:ASN Name: TISCALI-IT (Tiscali Italia SpA.)
:IP range connectivity: 1
:Registrar (per ASN): RIPE
:Country (per IP registrar): IT [Italy]
:Country Currency: EUR [euros]
:Country IP Range: 82.84.0.0 to 82.85.255.255
:Country fraud profile: Normal
:City (per outside source): Cagliari, Sardegna
:Country (per outside source): IT [Italy]
rivate (internal) IP? No
:IP address registrar: whois.ripe.net
:Known Proxy? No
:Link for WHOIS: 82.84.149.167
: While mswsystems.com is in Tampa, Florida.
:Registrant:
: Mark Wykoff
: 12506 Maverick Court
: Tampa, FL 33626
: US
: Domain name: MSWSYSTEMS.COM
: Administrative Contact:
: Wykoff, Mark ****@mswsystems.com
: Tampa, FL 33626
: US
: 7278045316
: Technical Contact:
: Tampa, FL 33626
: US
: 7278045316
Thanks for the sender email address analysis Michael. This makes it even more
evident that the OP is a fraudster in my book.
The use of the Tampa based domain name along with the Google street view of the
Maverick Court location strengthens my opinion that something fishy is going on.
