Pulse width modulation
Electron point
Feb 20, 2012
Hi Folks
I am fairly new to this - as my question will show....
Is there a way to reduce from 12 volts to say 2 volts without wasting power and needing a big heat sink when drawing about 10 amps ?.
Does a pulse width modulator do that? I see some advertise that they don't need heat sinks.
I'd like to make a pulse with modulator that is adjustable so as the unit gets hotter the power required remains the stable (over a range of temperatures)
Gerry
PWM, well, kinda.
It depends on what you're driving.
If it's a motor it will probably work, but for an electrical circuit you will need DC, in which case a switchmode regulator is required.
jackorocko
Apr 4, 2010
1,284
Power and heat are very closely related. Doesn't seem to me that you can maintain the same power level and reduce heat. A watt is a watt.
Rleo6965
Jan 22, 2012
585
My idea was to have a power transformer that have multi-tapped secondary with automatic selector switch to feed selected bridge rectifier then pass a voltage regulator. Voltage drop to series pass transistor therefore would be minimal. It's only an idea. But maybe it can be done. This is linear solution not pwm.
