ShamShoon
- Jan 1, 1970
- 0
Can somebody help me understand the circuit in http://www.edn.com/article/CA6531584.html
an NE555 based voltage to frequency converter. I tried simulating the
circuit in LTSpice but couldn't get the NE555 to work.
The article says that first the capacitor will be charging with an
applied negative input voltage. So far so good. When the output
reaches a certain voltage the discharge transistor Q1 will turn on and
reduce the output voltage.
This is what I don't get. If the voltage is decreasing on the cap
after Q1 is turned on, we have now 3 currents at the negative input
junction of the OpAmp.
1) Q1 current going upside down
2) Input voltage current going from right to left through the
resistors P1,R1 (0 to a negative voltage)
3) Cap discharge current going from left to right (The only way I can
think of if the output voltage is decreasing).
So now we have at one junction, 3 positive currents going away from
the junction, which by KCL is impossible.
So what am I missing ??
Thank you.
Thank you.
