Pye 37K7225
DRead
Hi.
I am attempting to repair for personal satisfaction an old portable
1979-80 TV.
The problem I have is no picture, no sound and a pulsating power noise.
Any suggestions?
I
I.F.
Mr. Land said:
What's a "pulsating power noise"?
Hmm? 79/80 sounds a bit early for a SMPSU - if there's an overload the PSU
trips then tries to restart, this makes a pulsating or sometimes a breathing
noise.
DRead
Yes does sound as though it is trying to restart.
Any idea's?
I
I.F.
Any idea's?
Horizontal scan transistor maybe S/C?
Horizontal scan transformer maybe shorted turns or insulation breakdown?
Horizontal scan flyback tuning capacitor S/C
The tuning caps often crack or split when they fail, and you should have
done a thorough visual inspection by now anyway! Try disconnecting the
collector of the scan transistor - first test it for S/C then try powering
up with it disconnected. Note that the PSU may not take to being run with no
load so try connecting a 40W or 60W bulb from the feed to the collector to
chassis (GND) See if the PSU fires up and lights the bulb and it wasn't a
S/C transistor, this points to either shorted turns in the transformer or a
load on one of the scan derived supplies S/C - such as audio or vertical
sections. If the PSU still won't fire up its likely the scan transformer
primary winding is shorted to GND or the PSU itself is faulty!
I
I.F.
Any idea's?
The set probably contains a Philips chassis - do a search on the model
number to try and find the chassis type, I might just have the schematic!
