I own a 1951 PYE P28 radiogram and just turned it on after years…
It all lights up as it should and the valves light up inside… the record player spins and it makes a low humming noise…
Power wise it is all fine…
However this is all it does…
I cannot get the radio to make any sound…
Just a low hum, not a crackle as you’d expect from a radio…
The record player was upgraded in 1974 to a garrard one… probably because the original only played 78s and the owner wanted to play their brand new Elvis records…! Haven’t been able to test the record player other than it spinning round which it does as the audio output wire on it is not currently connected to amplifier…
Im sure the amplifier works as when you turn the volume dial it makes the crackle noise through the speakers so the amplifier is amplifying the volume dials crackle…
I have plugged an Ariel into the Ariel port on the back but makes no difference…
When you turn the tuner dial the internal metal grill slat thing turns with it inside but has got a bit of a wobble to it… won’t make any difference as the wires are not affected or strained…
Cabinet is in good nick and there it has the original receipt… and also a bit of paper relating to it from 1999 so possibly worked then if someone put that in one of its draws at that time…
Any help much appreciated,
I can do very basic repairs but hoping it’s more of a simple problem…
