John
- Jan 1, 1970
- 0
Model ocg600ml
34513 control board with date stamp 12-27/01
This unit had been in service for 2 or 3 years (installed by the
builder during construction of a new house).
Symptoms:
intermittent reversal, stopping mid-track, occasional loss of power to
wall-mounted button, occasional complete power off at end of travel
(door opened but light turned off when door stopped in the up
position)
Testing:
Unplugging the unit from the AC receptacle and plugging it back in
sometimes brought it back to life (briefly) and sometimes not.
Touching the housing sometimes brought it back to life (briefly) and
sometimes not.
Went looking for a bad solder joint - not common with a wave-soldered
board, but it was an *intermittent* problem.
The connections to the transformer pins looked "cold". Perhaps the
pins were not cleaned adequately at the factory, perhaps the wave tank
wasn't hot enough to handle the larger pins.
Resolution:
Resoldered the transformer pins to the board, using "real" solder
(60/40 from 20 years ago). Opened and closed the door 8 times without
any glitches.
My daughter has not reported any further problems with the garage door
opener ;-)
John
Email here: ads at wizardanswers dot com
Symptoms:
position)
Testing:
sometimes not.
Resolution:
any glitches.
opener ;-)
John
