Q on Sony "professional broadcast" RS422 pinouts
Peter
I am developing a product which is to drive a Sony or similar VTR.
I have the DB9 connector pinouts
1 GND
2 RXA
3 TXB
4 GND
5 GND
6 GND
7 RXB
8 TXA
9 GND
and it's working OK.
However, for an unrelated purpose I need to know whether the RS422
product being controlled actually connects to *all* the pins marked
GND.
I believe the straight-through DB9-DB9 cable normally used in these
applications does have all nine pins connected through, but is it
normal for the device itself to have GND on all of them?
Rich Grise
1 GND
2 RXA
3 TXB
4 GND
5 GND
6 GND
7 RXB
8 TXA
9 GND
GND.
Not at all. In a "normal" DB-9, several of those pins are used for
things like RTS, CTS, DTR, DSR, and RI.
But a cable should go straight through and not care, as long as both
ends are wired the same in the equipment.
Good Luck!
Rich
Eeyore
He said *RS-422* !
Graham
martin griffith
On Thu, 05 Oct 2006 15:02:27 +0100, in sci.electronics.design
1 GND
2 RXA
3 TXB
4 GND
5 GND
6 GND
7 RXB
8 TXA
9 GND
GND.
not quite,
pins 1 and 9 are chassis ground
the others are signal ground, but 5 is spare
So basically you have two sheilded twisted pair cables, each with a
ground, and ignore the rest
http://www.belle-nuit.com/archives/9pin.html
But in patch fields I just used the twisted pairs only, it works fine,
but that was with all the tech stuff chassis bolted to ground.
martin
