Question about hall effect / floating signal
Hdp160
Sep 11, 2016
10
Hi I want to add a manual switch to isolate a rotary flow sensor. (I'm guessing hall effect?) To stop it reporting flow several times a day.
Flow turbine sensor has 3 wires ... red (5v) black (gnd) and yellow (data pulses).
Ideally the switch will be 1 to 1.5m from sensor and 1 to1.5m away from PCB.. currently the sensor and PCB are about 400mm apart.
Please can someone advise the best way of going about this to avoid leaving the data line floating.
Sorry for the simple question but this is not my usual area.
Alec_t
Jul 7, 2015
3,821
A SPDT switch, with common as the PCB input, NC going to the sensor and NO going to one or other power rail (depending on what your PCB will accept as 'zero' flow?
Hdp160
Sep 11, 2016
10
Thanks very much, after I posted it occurred to me that the yellow wire which I refered to as data signal is probably more accurately a variable voltage returnIng from the flow (0v @no flow... +a few volts during flow) turbine and less likely to suffer from "spikes" so probably not requiring a pullup but probably pulldown.... so NC to ground do you think?
Alec_t
Jul 7, 2015
3,821
By using the terms NC and NO I may have implied the switch had bias. That wasn't the intention. If the switch is manually controlled then NC and NO are interchangeable fo this application.
