Question about making things "Turbo" or pulsing.
I need to make a swith send a pulsing signle. Low voltage for a video
game constoller. Can this be done with resistors or diodes? Whould thay
have something like this at radio shack?
Rich Webb
Depends on what you're comfortable with. One way would be a monostable
where the rising edge of the pulse triggers an astable. This could be
built out of discrete components or 555 timers (all available at Radio
Shack). If you don't want a delay (as in how computer keyboards normally
have a small delay before they start to auto-repeat) then a single
astable oscillator (again, discretes or a 555 timer) would do the trick.
Another approach would be a little 8-pin microcontroller with an
internal RC oscillator, so no crystal or external clock would be needed,
just power, ground, signal in, signal out. Might even be cheaper than
doing it with discretes. Radio Shack doesn't carry single
microcontrollers and what they do have (Basic Stamp) is overkill for
this. An ATtiny13 at about $1.40 qty one (Digikey) would be dead simple
to program for this.
You could fancy-up either approach with an enable switch, variable
delay, variable firing rate, indicator LEDs, sound, ...
Thanks! I'll look into thoes 555's. Sounds the easiest. I'm a self
tought person so this help. I know all the other stuff etc. Thanks!
Rich Webb
Wow, anybody got alink to the's 555 things at radio shacks site? lol.
In their infinite wisdom, RS has these listed under "transistors and
analog ICs" and, even more helpfully, doesn't find them in a search for
"555". Look for part number 276-1723 for the single timer (LM555) and
part number 276-1728 for the dual (LM556).
exxos
LTC6906
