John
- Jan 1, 1970
- 0
Last year I bought a table saw that had a magnetic starter. After a few
months it would not turn off. The relay had 4 poles but only used three, so
I found the bad pole and moved it to the unused one. Last week it happened
again, but I no fresh poles. But that's okay because I wanted to change the
saw to 240v anyhow, and that requires replacing the relay.
The old relay is an Potter and Beaufield (or something like that); with a
great big coil and nice solid looking contacts. It is only rated for 1hp
and the motor is 2hp, so the previous owner ran the hot through two contacts
figuring it was 1hp each. The repeated failure suggests that is a bad
scheme.
A 240v P&B replacement is $120, however I found a little plastic box rated
to 3hp for only $35 in the McMaster Carr Catalog! ( 7105K12) Considering it
is a third the size and price of the old one, and the old one was
inadequate, I am a little sceptical that it can actually handle 50% more
power.
But I know very little about relays, so maybe it is an improved technology.
Whatcha think, should I try it, or is it just throwing money out?
scheme.
power.
