Question about SDRAM
i don't understand some definitions about SDRAM:
1)COLUMN: smallest unit data....if SDRAM is 4Mx16(=1megx16x4banks), is
16 colum's number of bits or data out bits?Column's number of bits and
data out pins are always the same or can differ each other?
2)BANK: in datasheet i found 1,2,4,etc...are these bytes or cells? For
example, if bank=2, i obtain 2*16=32bit or 2*8=16bit?
It would be a good idea to identify the SDRAM that is troubling you.
My expectation would be that a 4Mx16 SDRAM would offer 4M of 16-bit
words, which implies a 16-bit parallel data output.
Addressing 4M of data requires a 22-bit word. This could be presented
to the chip at 22 different address data input pins, but address lines
are often multuplexed; you could use 11 -bit to select a particular
row of data out of 2048 columns, then latch this high-order address
data and use the same 11 input pins to select particular row out of
2048, thus selecting the particlar word a the intersection of the
selelcted row and column. In principle you need a 12th input pin to
distinguish between rows and columns, but it isn't always possible to
identify a specific pin that makes this distinction.
If the data sheet talks about banks of data, it could be that the
address is being read in in three steps into 8 address pins, first you
select one bank, then one column and finally one row to pick out a
particular word. In principle you then have to devote a nineth and
tenth pin to distinguishing the bank address from the column address
from the row address, but this doesn't have to be the way it is done.
Thanks for the help
http://download.micron.com/pdf/datasheets/dram/sdram/64MSDRAM.pdf
Ok, but i don't understand how many bit can i obtain from a single
address: for example, if i use an 4Mx16 memory, with a single address,
i obtain a 16bit data?Single cell is 16bit wide?
Pardon, i have made a big error: what i mean is BURST, not BANK
(excuse me)....I've found Burst length=1,2,4,ecc :These values are
bytes (Burst_length=2=>2*8=16 bit) or number of cells (2*16=32)?
N
Nobody
A DRAM is a two dimensional grid of cells, optionally partitioned into
multiple banks. In order to read/write data, you first have to "open"
a specific row, which is relatively slow. Once the row has been opened,
you select which columns (bits) to read/write for that row.
The width of the data bus determines how many columns are read/written at
a time. The selected columns are aligned to a multiple of this width. E.g.
for a 16-bit DRAM, a column address of zero connects columns 0-15 to the
data pins, a column address of one connects columns 16-31, etc.
The rows are divided into banks.
If the DRAM has multiple banks, each bank can have a row open, and you
can interleave commands between banks. E.g. issue a command to one bank to
open a specific row, then immediately start a burst transfer for the
currently-open row on a second bank. By the time the transfer has
completed, the first bank's row will have been opened.
