Question in Char Separating
brian22
Jul 19, 2013
40
how to separate the content of a char ex. Hello World then i will store the World in byte? tnx
The world will not fit in a byte.
brian22
Jul 19, 2013
40
how about in char array?
i'm using a gsm lib and i want to separate the message in smsbuffer and store it in another byte/char array. tnx
gorgon
Jun 6, 2011
603
Normally an array of char is called a string. So you need to search for string manipulating functions.
You apparently need to learn programming. I presume, from your use of "char" that you are using C. Find a C tutorial and study it.
brian22
Jul 19, 2013
40
i used arduino lib
Regexp.h
Code:
MatchState ms;
  char * str = smsbuffer;
  ms.Target (str);
  unsigned int index = 0;
  char buf [100];
  while (true)
  char result = ms.Match ("(%a+)" "(%-?%d+)", index);
   if (result == REGEXP_MATCHED){
     for (int j = 0; j < ms.level; j++);
     gsm.WritePhoneNumber(result[j],(%-?%d+);
     index = ms.MatchStart + ms.MatchLength;
   else
     break;
can you help how to correct this one.. tnx
