Question regarding using a plug adapter.
edwardkim89
May 3, 2021
Hello there,
I am looking into buying 2 continuous LED lighting from Nanlite.
One is Forza 300 and the other is Forza 500.
https://www.bhphotovideo.com/c/product/1476381-REG/nanlite_12_2001_forza_300_led_monolight.html
https://www.bhphotovideo.com/c/product/1476382-REG/nanlite_12_2026_forza_500_led_monolight.html
I'm buying through ebay, because it ships to South Korea (where I'm currently based), and it's cheaper than buying
from local electronics stores in South Korea.
But the thing is, it only comes with 3-pin AU 230V plug power cable.
And we use 220v in Korea. So I would have to buy a converter.
I know Forza 500 and 300 are strong lights, and I was wondering
if it's safe to use the plug adapt or do I need something like a step up & down transformer?
Edward
bertus
3,877
Did you read the specs?
Power
AC Input Power 110 to 240 VAC, 50 / 60 Hz
DC Input Power 48 VDC
Power Source AC Adapter, External Battery
Bertus
edwardkim89
May 3, 2021
Power
Bertus
Hey Bertus, thanks for you reply.
Does that mean it's OK?
Sorry, I'm not well educated on these things.
bertus
3,877
Any supply voltage for the adapter between 110 and 240 Volts AC will work, so the 220 Volts in your area is no problem.
Bertus
