Question store display lcd led ips
Status
Not open for further replies.
nogueiraat
Apr 24, 2021
38
If you store an any IPS LED LCD panel without using it for a long time (many years), will the pixels develop dead and stuck pixels? Can liquid crystals settle over time, leading to slow response times or "stuckness", where they may not change state correctly when turned on after years of inactivity? Do LEDs and backlights die or lose efficiency?
nogueiraat
Apr 24, 2021
38
long-term storage of 3.5" IPS LCD displays from handheld consoles is very complicated? Do they degrade rapidly at high temperatures of 34-38°C and humidity of 55-68%? Under these conditions, do their LEDs lose brightness, contrast, and color, and are the liquid crystals permanently damaged?
14,317
See the manufacturer's relöiability data for your LCD.
nogueiraat
Apr 24, 2021
38
any pdf example this data realiable in pdf for display 3.5" lcd ips? in datasheet no more information
Delta Prime
Jul 29, 2020
2,996
Here you go..
Example of manufacturer's reliability data for LCD.
3.5 inch LCD displays are negligible. Meaning in this case size does not matter.
  • LongTermReliability.pdf
nogueiraat
Apr 24, 2021
38
not shows humidity and temperature information for storage not degrade leds, lcd and polarize film
Delta Prime
Jul 29, 2020
2,996
If you don’t know how to store them then you shouldn’t have them.
I’ll tell you what why don’t you show me; make model manufacture. My crystal ball is buffering right now.
Delta Prime
Jul 29, 2020
2,996
I would suggest put them in an environmental oven find out for yourself.
Please tell us the results when you come back bye-bye.
Zakholland441
Dec 17, 2025
3
Long-term storage alone typically doesn't result in dead or stuck pixels on IPS screens, based on my observations. Slow response is more about aging with usage than simply sitting idle, because liquid crystals don't actually "settle" in a way that damages them. Although LEDs and backlights can gradually lose efficiency over many years, they usually keep up fairly well if stored under suitable circumstances (cold, dry, and not powered).
Status
