QUESTION: What is a "locally active resistor"?
S Claus
Hi all
I came across the article on "Chua's circuit" in Wikipedia (at ). This
circuit "exhibits classic chaos theory behavior" even though it is
composed only of "standard components" (resistors, capacitors,
inductors).
This article also lists the criteria that a circuit must meet in order
to display chaotic behaviour. One of the criteria (#2) is:
One or more locally active resistors
The question I wanted to ask is, what is a "locally active resistor"?
Aren't all resistors in a circuit locally active? Or can there be
"remotely active" resistors, and in what kind of situation would that
be?
Thanks in advance
V
Varactor
Hi all
inductors).
be?
Thanks in advance
Read this:
http://crossgroup.caltech.edu/chaos_new/Chua.html
Cheers
Paul E. Schoen
Hi all
inductors).
be?
Thanks in advance
Read this:
Cheers
The simulation applet was interesting. The circuit seemed fairly stable for
higher values of R, and the intensity of oscillation diminished. But when
the value was lowered the pattern expanded and eventually hit the supply
rails. Order was eventually restored by raising the value. It seemed like a
resonance phenomenon.
Paul
neon
Oct 21, 2006
1,325
there are never active resistors capacitors coil SWITCHES and so forth. They are all passive conponents. MAYBE THEY ARE FROM mars AND BECOME ALIVE.
