Questions cable controls snes
gamer87
Mar 11, 2017
261
the cables of my Snes controls are dry and stiff. is there a chemical product to return the cable flexibility?
Kabelsalat
Jul 5, 2011
198
No, unfortunately there isn't. And if it somehow existed such a substance, how should you get it applied into the whole volume of rubber and not just the surface ?
HarryA
Jan 22, 2017
90
Make a small loop in the cable and soak it in acetone as a test; works for me. Save the used acetone to clean paint brushes with.
bertus
3,882
The plasticizer has probably evaporated from the cable.
Watch out with acetone.
Acetone might dissolve the plastic.
From the wiki:
Solvent
Acetone is a good solvent for many plastics and some synthetic fibers. It is used for thinning polyester resin, cleaning tools used with it, and dissolving two-part epoxies and superglue before they harden. It is used as one of the volatile components of some paints and varnishes. As a heavy-duty degreaser, it is useful in the preparation of metal prior to painting or soldering, and to remove rosin flux after soldering, which helps to prevent the rusty bolt effect.
https://en.wikipedia.org/wiki/Acetone
Bertus
HarryA
Jan 22, 2017
90
Yes It may dissolve the plastic at the connectors. One can get cable extensions for 8$ and splice them in for new cables perhaps?
dave9
Mar 5, 2017
1,191
You could try an automotive vinyl/rubber conditioner product, but if it's vinyl and had significant UV (sun) exposure, it may eventually crack apart no matter what you do except to avoid flexing it much.
gamer87
Mar 11, 2017
261
Does this product recover the cable's flexibility?
dave9
Mar 5, 2017
1,191
lol, I'd try the vinyl conditioner first because once you put that on, nothing else is getting into the pores. That is more of a protectant than a conditioner.
gamer87
Mar 11, 2017
261
This vinyl conditioner product is difficult to find in Brazil is it very different from silicone gel? how is it working
dave9
Mar 5, 2017
1,191
I know nothing about Brazilian Auto Parts stores, but any with a good stock of products should have an entire wall devoted to cleaning and conditioning products. Amazon.com.br appears to have Mother's Vinyl & Rubber Care, perhaps other suitable products too. Normally a conditioner would have propylene glycol in addition to silica gel.
Martaine2005
May 12, 2015
5,318
Ask @Ratch , he will be there soon. He can bring you big drums of the stuff.
WARNING: Never mention tide movement times or current flow to him!
Martin
gamer87
Mar 11, 2017
261
could you recommend me good products and the necessary composition?
were you able to recover dry rubber and plastic cables using this product? are they flexible again?
dave9
Mar 5, 2017
1,191
There is no forever. Follow best practices or don't but the worst thing to do is waste time while time still has its way...
gamer87
Mar 11, 2017
261
gamer87
Mar 11, 2017
261
